Lian Li 215x and Noctua NH-D15
Solved by Bombastinator,
The variance of the case is likely going to be way less than 1mm, but the variance in the air cooler may not be due to the way heat pipes are made. The 165mm claim of the cooler may be a “can’t be more than” measurement though in which case there is a decent chance that the particular cooler you buy could be a lot less than 165mm. I would say the fit will need to be checked and it’s gonna be pretty close, but it probably will work. If it was a no-name brand that “probably” would be more of a “might” but noctua is a long term brand so unless they’ve changed their manufacturing process or are farming cooler pipe filling to other makers I doubt it will be a problem.
