Fan Splitters are not missing a pin
Solved by NorKris,
we know that:
1 pin is ground
2 12v
3 RPM
4 PWM
so the picureu guys are using of the wires are wrong, anyways use tool of some kind to bend this pin down (pin nr 3)
Problem solved
Featured Topics
heckboi ·
Posted in Cases and Mods0 -
1
heckboi ·
Posted in Graphics Cards0 -
6
2
2
Cheersmate ·
Posted in CPUs, Motherboards, and Memory9 -
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
