I'm confused on if I would be able to add 9 argb fans.
so the fans I want to get are the Phanteks M25-120 PWM D-RGB 84.26 CFM 120 mm Fans 3-Pack but I was wondering if I was able to use 9 of them in the NZXT H6 flow with the (EDIT:   it says you can daisy chain 3 of them together so it works i think???)
ASRock B650 Steel Legend WiFi ATX AM5 Motherboard  I don't really know what I'm talking about when it comes to this.
any help/info is welcomed!
The case supports up to 9 fans. Comes with 3 pre-installed fans. You can get a fan controller that supports RGB.
The case can fit 9 120mm fans so no worries there. For the fans I don't see why it wouldn't work as long as the fans don't exceed the total output for a single motherboard fan header. The Phanteks site says a single fan draws 0.3 amps so 3 fans per header should be possible. I'm not familiar with Phanteks argb so I don't know if a hub is needed for 9 or just daisy chaining them to the header will work.
(fan splitters and either an argb hub or argb splitter needed if not provided in the box)
