I have an iGPU and it has a vram of 1GB. And I need to increase it to 2GB but my BIOS does not have the option. HELP
Solved by FloRolf,
That's weird because your vram is just dram that is used by the igpu. Naturally windows is smart enough to use dram after your vram runs out. In your case it should just use more dram.
Edit: what I am saying is, theoretically your system shouldn't care whether you have 1gb, 2gb or just 100mb allocated to the igpu as it will just use as much as it needs/until dram runs out.
