When I start to download a larger file, my speeds tank to about 1 mb/s. If I disconnect from the router, and reconnect, it'll go back up to 25 mb/s for a short time, and then drop back down.
This only really happens when I'm downloading larger files. Or, when the TV is on.
Any ideas what might cause this? Would using a better router help? Currently I believe it's an older Telus modem/router combo.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1343789-internet-speed-issues/
Is this for all files or only files from a specific source?
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775807
All files, and sometimes huge slowdowns on YT.
Just now, Moonzy said:
connected to your AP using cable or wifi?
Right, guess that would have helped. Wifi AC. Cable isn't happening.
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775830
Could be that the error appears all the time, but only shows itself to you in form of spikes when downloading "larger files"
but most common issue in download spikes are: router problem, connection problem, adapter problem, or a shitty isp
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775831
i've had wifi dongles overheat and just drops out before when sustaining 20mbps for longer than a few minutes
perhaps that's the case
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775834
16 minutes ago, Haraikomono said:
How about power-lan ?
Wie sicher ist Power-LAN? - com! professional
Its not perfect, but many magnitudes better than wifi
And they are pretty cheap
Have these improved at all? I used them probably like 7 years ago and they were awful.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775878
Maybe they work in some homes, but whenever I've used them they've been pretty terrible, even under ideal situations. The last time I used mine I was lucky to get 5 Mb/s through them.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14775900
I mean, that's kind of like saying "the problem could be the car, the driver, or the road" if you have a problem with your car 😂
But thanks.
3 hours ago, Flapjack30 said:
Probably the AP.
That was kind of the thought I had too. Perhaps it's time to upgrade to WiFi 6.
I'd considered that too, but it does it when trying to stream at times as well. I would ideally like to get a better internal card, instead of the USB one I have now, but that's on teh list much further down the line of purchases.
That'd mean sacrificing the plug on the wall I need to plug in the computer, since they generally take up the entire outlet.
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776154
Yea, so, sustained load
Mine gives me back the outlet so...
Albeit power line is not a cure-all medicine, I've had issues with mine too
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776157
Not quite. It plays videos perfectly fine most of the time, which is the same load.
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776181
Videos are bursts of data, no?
I never had issue with mine until
1) I transfer large files to and from
2) I play Minecraft which can go up to 20mbps upload, which overheats it real quick
It's easy to check, just disconnect it and connect it back before it cools, it should throttle real quick
Then disconnect and let it cool longer, then try again, it should take longer to throttle
Not to be pessimistic but I owned 3 wifi dongles, all three of them overheats near the same condition on different PC, one of them even died
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776188
yes, even I had issues with them many years back. But couple years ago, I installed them at my friends house, because his house layout is not so good.
And, I have to say, that I am positively surprised by the performance.
Of course, you will need to have a good pair. And the main brand, helps in this case alot
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776597
@dizmo
Are you at least able to test performance over ethernet? That would help to eliminate the problem to WiFi or the router.
What make/model of router and WiFi card?
How far is the computer from the wireless router? Any walls or floors in between?
Perform a wireless survey
Download. Install. Run. Go to ‘Analyze’ tab. Switch between 2.4GHz and 5GHz to see the analyses. Take screenshot. Post here.
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14776720
  • 2 weeks later...
But they're always playing, if that was the issue it'd be a lot more prevalent.
I thought about it some, and I think it's probably Steam updating things in the background.
On 6/2/2021 at 3:43 AM, Falcon1986 said:
@dizmo
The router is just whatever Telus provided, and the WiFi is a Netgear A6210.
It's not too far, maybe 25 feet, and a few walls. The adapter has performed fine with a Shaw modem through the same number of walls and twice the distance.
I ended up buying an Asus AC68 router and WiFi card, so we'll see if those change anything.
https://linustechtips.com/topic/1343789-internet-speed-issues/#findComment-14799208
