Portable Dac/Amp for DT 990 Pros (android)
Solved by rice guru,
14 minutes ago, Dreaper said:So that should work then? Its about 150 and doesn't seem too huge.
yep its nnot too unwieldy. its is thick and does have a bit of heft. if you are worried about how portable it can be the hip dac is not a bad unit as well just weaker聽
Featured Topics
Vectraat 路
Posted in General Discussion0 -
kodokuj 路
2
1
play_circle_filled
Latest From ShortCircuit:
Feels like I'm wearing nothing at all... - Shokz OpenFit Air
