How often should i re-apply thermal paste, and clean/oil my fans?
TristanD79
Years. I've never replaced thermal paste or oiled my fans. Just use compressed air to blow the dust off of them.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
- Re-apply thermal paste when you start to notice a significant difference in temperatures (after years of use).
- Clean your fans when they start to accumulate dusk, oiling them isn't always necessary.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
10 minutes ago, TristanD79 said:
Essentially what maintenance should I be doing with my PC?
Generally cleaning off dust is all you should need to do.  Good thermal paste should last 10 years or so, only replace it if you notice your temperatures are significantly higher than they used to be.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
