Will a Cooler Master Hyper 212 RGB Black Edition Fit on a GB H310M H2.0 MoBo?
Solved by WoodenMarker,
44 minutes ago, Arka Mukherjee said:I am using the Ant Esports ICE 300TG mid tower case.
The case lists up to 155mm of clearance for a cooler so I wouldn't recommend the 159mm tall Hyper 212 RGB BE unless you've seen someone fit the cooler in in this case.
Where are you shopping / located? Budget?
dita ·
Posted in Graphics Cards6 -
razor32308 ·
Posted in New Builds and Planning2 -
5
huckk ·
Posted in Laptops and Pre-Built Systems4 -
8
4
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
