Other Possible uses for a CMP Card?
Brums
I did some googling and didn't see a clear answer, Can a CMP Card be used for Virtual Machines for non mining VM's which could use accelerated graphics e.g. a Plex Server VM?
CPU: AMD Ryzen 9 5950x @ 4573.93 MHz All Core (CPU-Z), Motherboard: Asus ROG CROSSHAIR VIII IMPACT, RAM: Corsair CMT32GX4M2Z3600C14, GPU: Asus ROG Strix LC Radeon RX 6900 XT, Case: Fractal Design Node 804, Storage: Corsair Force MP510 1920 GB x 2, PSU: Corsair AX1600i, Display(s): Asus 27" VG27AQ x 3, Cooling: Corsair iCUE H100i Elite Capellix & Fans: Corsair ML120 Pro x 8, Corsair ML140 Pro x 1 & Noctua NF-A12x15 x 1, Keyboard: Logitech G915, Mouse: Logitech G700, Mouse Pad: SteelSeries I-2 Glass Mouse Pad, Operating Systems: Windows 10 & Ubuntu
Afaik they should operate just like a normal GPU, just without display outputs. If you have an integrated GPU that can work as a display output, you should still be able to use the CMP as an acccelerator.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
1 minute ago, Stahlmann said:
Afaik they should operate just like a normal GPU, just without display outputs. If you have an integrated CPU that can work as a display output, you should still be able to use the CMP as an acccelerator.
Thanks @Stahlmann
