Use 3rd monitor as mirror of currently active monitor
@JishakuImagine moving your mouse off screen, losing the cursor, and then frantically toggling between the two modes each time causing your PC to lag because switching display properties really, really interrupts a GPU. And then oh I finally found my mouse. So unless you also want to somehow program a tool that if your mouse cross over the 2 adjacent vertical line of pixels between the two monitors, then triggers the change, then go for it, but I can't program for shit. I imagine if you have something like a gaming keyboard or a hotkey program, it shouldn't be that hard to program a key combo after you understand the code for display properties and display switching.
It might even be easier to program a separate utility to detect when your mouse is on a certain monitor that then simulates the key combo. And if you used a hotkeys program it might be possible that this simulation is actually picked up.
So I guess you either have the choices of ignoring this all and maybe getting somebody else's help, or learning the code behind Window's display manager and creating mods for it. DO NOT come back to ask me anything, I can't code to save my life.
