Fan motor humming / rattling noise and PWM
On 5/19/2021 at 10:23 AM, PandaGab68 said:'' Is there any point to put noctua's LNA adapters between fans and a PWM fan hub ? ''
Yes as it will reduce the max speed, therefore the sound.
The LNA is only good if there's otherwise no fan control. It doesn't let the fan run any slower than it otherwise can with fan control.
On 5/19/2021 at 11:58 AM, Sbilit said:The [Pure Wings 2 140mm] makes a small rattling sound that bothers me, it doesn't get louder as the fan runs faster, but the "tic" frequency gets higher. That's why I guess it is a "motor noise". The blowing sound is not disturbing, it is smooth and soft and the Silent Base 802 makes is quiet.
What I'm looking for is a 140mm fan that don't make "motor noise" at all.
It seems that the [Silent Wings 3 120mm PWM] delivered with my ventirad doesn't do that. Be quiet! describe on their site for the Silent Wings 3 "6-pole fan motor with three phases giving very low power consumption and less vibration", I guess this what corrects the noise I'm talking about.
I saw on a french hardware forum someone with 3 diffent Be quiet! fans, according to him, the humming noise was :
- Present on the [Silent Wings 2 140mm PWM],
- Slightly audible on the [Silent Wings 3 140mm PWM], that I confirm with 120mm, it is there but if you put your head in the case
- Completly absent on the [Silent Wings 2 ??mm DC]
Is this a PWM counterpart ? Handled by Silent Wings 3 only ?
I checked : Noctua says for SSO :
"Combining the proven concept of hydrodynamic bearing with an additional magnet that supports the self-stabilisation of the rotor axis, our time-tested SSO-Bearing technology has become synonymous with supremely quiet operation and exceptional long-term stability"
"In addition to the stabilisation during the start-up phase of the fan, the supporting magnet allows for a more exact centring of the axis within the bearing shell and thus further reduces bearing resistance, abrasion and noise emission."
"The SSO bearing not only surpasses the quietness of conventional sleeve bearings but also the long-term stability of current top-of-the-line ball bearings."
"Silent enthusiasts and industry clients alike swear by its proven, time-tested quality."
https://noctua.at/en/sso-bearing https://noctua.at/en/sso2-bearing
So according to them, they are completly silent.
But I can read on reddit people complaining about Noctua NF-A14 PWM humming noise...
It does, thanks !
Check and see if the noise persists when outside of the case. The blades may be hitting the case or a cable.
PWM introduces ticking on many fans due to the nature of it using 12v pulses. Noctuas are the only fans I've encountered that don't seem to have this issue due to the gradual pulse used.
Noctua isn't claiming that the bearing is silent. The quote is just saying that enthusiasts of silence say that the bearing is high quality.
On 5/19/2021 at 8:47 AM, Sbilit said:Can I connect a 3 pin fan to a PWM fan hub to reduce speed without any damage ?
3pin fans lack the 4th pin and pwm ic needed to modulate the incoming 12v signal. Sending a 12v pwm signal to a 3pin fan will result in 100% rpm and no fan control.
