How to set-up Dual Monitor?
Innsight
Good day everyone! I have my motherboard  Msi a320m pro vh plus and Athlon 200GE. I just wondering why my pc can't detect my second monitor display. I connected primary monitor (which I'm currently using) on HDMI port, and the second one (old monitor) connected on the VGA port. I already updated the necessary drivers. I also want to the bios set up and I do found integrated graphics configuration. I chose the IGD but still don't see an option for dual monitor. Is this really like this? Do I really need a GPU or a Video Card? How can I have dual monitor set up
Have you updated your BIOS to the latest version? Your configuration should work automatically without any special settings. Bear in mind that your second monitor may not be detected while in the BIOS, but should be detected once Windows is booted.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
