Strange RGB Fans question Advise
bubuie
Guys, hello hope you are doing well, in the past I have had the Case which came with 3 RGB fans, those fans are connected by the Molex LED (White) connector to PSU ; and their fan colors are changed by the Reset button (front connector)
Atm I have deepcool dmesh55 4F Case, where this reset button is just gone only power switch and led etc are available, is there any other ways to change colors of the RGB fans of those without front connector reset button ? in static it is rainbow one.
Please find attached Photos of the RGB Fans
Anything that shorts these 2 pins together.
F@H
GPD Win 2
any alternatives for that reset SW connector? can I connect it with power SW?
you could use a small switch with a Dupont connector
║__________________║ hardware_____________________________________________________ ║
║ cpu ______________║ ryzen 9 5900x_________________________________________________ ║
║ GPU______________║ ASUS strix LC RX6800xt______________________________________ _║
║ motherboard_______ ║ asus crosshair formulla VIII______________________________________║
║ memory___________║ CMW32GX4M2Z3600C18 ______________________________________║
║ SSD______________║ Samsung 980 PRO 1TB_________________________________________ ║
║ PSU______________║ Corsair RM850x 850W _______________________ __________________║
║ CPU cooler _______ ║ Be Quiet be quiet! PURE LOOP 360mm ____________________________║
║ Case_____________ ║ Thermaltake Core X71 __________________________________________║
║ HDD_____________ ║ 2TB and 6TB HDD ____________________________________________║
║ Front IO__________   ║ LG blu-ray drive & 3.5" card reader, [trough a 5.25 to 3.5 bay]__________║
║ OS_______________ ║ Windows 10 PRO______________________________________________║
can you suggest any switch for that? I am not familiar with those....
Any switch would be fine, as you make your own dupont connector. and add a switch to it.
