which cooler is awesome for 5900x
Mohamed Batot
2 minutes ago, Mohamed Batot said:
i need best cooler for 5900x under 120$ any recommendations?
Fuma 2 for normal use/pbo provided you have a decent airflow case and an environment that's at a reasonable temperature (under around 75f or 24c), Artic liquid freezer II 280mm if your case supports it and you want to go overkill, or you have a hotter environment, lower-airflow case, if you want to overclock heavily, whatever.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
nh d15
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Scythe Fuma 2, Macho Rev B, Scythe Ninja 5  all are good air cooling options.
240mm+ Arctic Liquid Freezer, EK D-RGB AIO, Lian Li Galad, are some liquid cooling options
what about ARCTIC Liquid Freezer II 360?
Slightly better, pricier iirc.
do you know if cmp 505 support ARCTIC Liquid Freezer II 360?
It does. For your CPU, I'd probably recommend a 360 in that case, airflow is probably garbage. Or I might just recommend getting another, higher-airflow case.
iam planning to get h500p or h500m cooler master soon
any high end air cooler ?
Noctua NH-D15 SE-AM4
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
i have ATC800 and it's bad with cooling temp be 85 with games
 NH-D15 should be much better? or should i go with ARCTIC Liquid Freezer II 280 ?
Both are excellent choices, also Fuma 2 that was mentioned before is a great option.
I edit my posts more often than not
ATC800 is midrange cooler right?
Not a cooler I've heard much about but does seem quite high-end actually.  6 heatpipes and 2 fans - signs of high end.
I'd go with the Arctic Liquid Freezer if to see significant improvement.
I was considering Arctic but their lack of commitment via their 2 year warranty was concerning.
Quote
Quote
Quote
Quote
 i wanna to get air cooler Noctua NH-D15 but iam afraid it not bee enough for 5900x
NZXT Kraken X73 360mm and ARCTIC Liquid Freezer II 360 are same price should i go with NZXT Kraken X73 ?
I'm running mine currently with a U12S, plus an additional fan. Stock, temps never got over 81C under 100% load. With PBO and the new curve optimizer enabled with a -30 offset, I knocked a full 10C off that (71C at 100%) and got a nice clock bump to boot. I'm running +100-150MHz on every core, with a max boost of 4.95GHz.
Long and short, you actually don't need that much of an aggressive cooling solution for the 5900X, especially if you undervolt it (and you should).
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
The NH-D15 would cool better. The Liquid Freezer II 280 / 360 would cool even better.
The ATC800 is certainly far from high performance.
https://www.geeknetic.es/Review/1865/Disipador-Arctic-Freezer-50-Review.html
https://quasarzone.com/bbs/qc_qsz/views/692994
https://www.zeden.net/actu/25524-ZeDen-teste-le-ventirad-ATC800-de-chez-AORUS/5
I have a Bitspower CPU Block Digital RGB Summit M Acrylic, i got it for 50 bucks. Keeps my 5900x damn cold, under load i get to about 60c
It's way more than sufficient.
i bought nzxt x73 cus it's 200$ and i bought NH-D15 in my country i will pay 200$ too so i bought x73 Thanks guys !
