9pin usb port
Go to solution Solved by dilpickle,
15 hours ago, Bitter said:
https://support.hp.com/us-en/document/c05939208
If this is your motherboard then you have a special PCIe slot made just for WAN/BT cards in the lower right, some HP bioses only allow certain Wifi/bluetooth cards to be used. You'll need to google and find out if that's your situation or not, if it is not or if you can find an allowed card you can much much more easily do what you're looking to do with a simple swap of the wifi card for a better one.
@InfinityVoidX
This is your answer.
If this doesn't work you can go with a USB bluetooth dongle I mentioned earlier.
Might not have one.
You you specify on what card you have?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14669932
Just now, InfinityVoidX said:
wdym what card??
nvm  @emosun already confirmed my hypothesys. That board doesn't have that connector.
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14669943
4 minutes ago, dilpickle said:
You can add a PCI-E bluetooth card if you want. I'm not sure what that has to do with a USB port.
Most PCIe cards with Bluetooth connect through USB. That's why OP needs a USB header.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14669977
Yeah I just found that out. In that case just get a USB adapter like this:
https://www.amazon.com/ZEXMTE-Bluetooth-Receiver-Transfer-Wireless/dp/B0775YF36R
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14669999
the USB ports will be used for power and a few other functions if the card doesnt come with a connector on it for plugging into the PSU.
i am going to say that it will not have the USB connector because most HP boards are used in prebuilds and they are not meant to have all the extra overclocking or RGB you can have with buying your components seperately.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671162
Wi-Fi and Bluetooth cards don't use the USB connection for power; it's used for Bluetooth data. Also, having internal USB headers has absolutely nothing to do with overclocking or RGB features. Lots of prebuilts from the likes of HP and others use similar boards across a line of machines, and sometimes the headers are included on the board but aren't used.
This was very common in the late 2000s with HP and Compaq machines. Some of their computers included card readers that connected to internal USB headers, and other machines didn't. The machines that didn't usually had the same (or very similar) boards as the higher end models, and the headers were just left unused.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671175
if they dont have another way to get power apart from the PCIe slot they might be plugged into. then they have no choice but to use the USB header for power to the card. and you might be rignt on the overclocking but completely wrong about internal USB headers not being used for RGB.. any corsair product like the commander pro uses an internal USB header for the data to control the RGB and a SATA connection for power. on prebuilds you might be right on the RGB too but most prebuilt systems are the low end of components with the same price as a DIY computer so it wouldnt surprise me but just saying that the internal USB headers has nothing to do with RGB is incorrect.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671212
Sorry, I worded that poorly. They aren't just associated with RGB. They're also used for card readers, front panel ports, and more. Hell, HP used to use them for a removable hard drive system they had.
The cards aren't using the USB headers for power. If the card didn't have a USB header it wouldn't have a connector for power from the PSU. It's for data.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671252
i think you are thinking about the wrong kind of USB header. the one the poster is talking about is only 9 pins which it would only be used for RGB and/or power if no other way to connect it (but i doubt that). the ones i think you are thinking of are the ones you would connect the front IO to. the pic below is of my motherboard a MSI z370 gaming plus. the BLUE is the internal USB headers used for things like RGB and the GREEN is used for the front IO USB.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671271
No, no I'm not. You're comparing 2 different types of USB headers: USB 3 (the ones you've marked for front I/O) and USB 2 (the 9 pin connectors). USB 2 headers existed before USB 3, and they were most certainly used for front I/O. Bluetooth PCIe cards connect to the USB 2 headers in order to connect to the computer. They get power from the PCIe slot.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671280
actually no i have not. that is what i think you were doing because how i said it is exactly how i have my computer hooked up right now. the two Green ones are for the USB ports on the front of the computer case. the ones with Blue even say USB on them and are for things like RGB for inside the case. bKWClsZh.png.jpg
-CW-8960071-Gallery-CW-8960071-1.png_1200Wx1200H
the one bigger plug on the second pic is the SATA for power and the oiher is the USB plug.
-CC-8900156-Gallery-CC-8900156-1.heic
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671337
the one bigger plug on the second pic is the SATA for power and the oiher is the USB plug. -CC-8900156-Gallery-CC-8900156-1.heic 152.17 kB · 1 dnload
I don't think you're understanding. The headers you're saying are for things inside the case are the same thing as the ones for the front panel - they're just USB 2 instead of 3. They are not at all limited to internal devices like RGB controllers. Yes, they can be used for internal devices, but in years past they were also used for front panel devices like USB 2 ports and card readers. I can explain more if you'd like.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671364
in years past yes as infinityvoidx would have them if they actually had them on the board but i am correct in what i said. the green ones are for the IO and the blue ones used for internal USB things only because the plugs have changed on the parts. even the manuals for todays tell you that they are for RGB things. i used to have an apevia x hermes case and noiw have a corsair obsidan 1000d.
and i attached a 3rd pic in my last comment but you have to open it in a photo viewer of some kind.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671382
Look, I know what I'm talking about. I just bought a brand new case like 3 weeks ago that uses one of those 9 pin headers for one of the front USB ports. If you'd like I can send you a picture. Those USB 2 headers have not been left just for internal devices.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671389
sure go ahead as i am sure infinityvoidx could use it too. and i know what i am talking about too. i just bought myself a new case about the same time and my previous one didnt use those USB headers on my board. it used one of the two green ones i showed you. cases vary depending on who they are but they are getting away from the USB 2 you claim and going towards the ones like the one i mentioned.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671402
PCIe Bluetooth/Wifi cards often use a laptop module on them connected to a mini PCIe port. In laptops this port has a type of bifurcation for lack of a better term to allow two devices to share one PCIe 1x slot. In desktop PC motherboards this is almost always NOT the case for a 1x slot.  When you connect the PCIe card to the 1x slot it will see the Wifi portion of the card but not the Bluetooth portion because the slot is not split for both devices and the Wifi device always has priority for some reason. To use the Bluetooth part you MUST connect it to an internal USB 1.0 or 2.0 header which is a 9 pin connection. You can get a USB 3.0 to 2.0 adapter, you can get an internal USB hub that will break out 3.0 and 2.0 headers, or you can get a USB 2.0 hub that will give you more internal USB 2.0 ports.
@tdkid If you would like I can get some photos of my current X470 motherboard using BOTH the USB 3.0 and USB 2.0 headers for front panel IO as well as plenty of other older motherboards with only 9 pin USB 2.0 headers on them. You seem to have only been using/building PC's since USB 3.0 and it's 19 pin internal header has been a thing. It's rare to see new cases now with USB 2.0 9 pin internal headers used for front I/O so I can understand your confusion about this, but believe me it used to be that the 9 pin header was for front panel USB ports before USB 3.0 came around. USB has been pretty awesome if I may say so, before USB and USB mass storage moving data between PC's was a real bear either needing fat stacks of floppy disks and WinZip to compress the files into separate 1.4MB Zip files or the know-how to connect an external hard drive to a very very slow serial port and then spending hours waiting for files to copy over. It was pretty awful, and you needed a separate special printer port and a separate port for a joystick, a mouse, and a keyboard. Nothing interchanged and almost everything needed the PC to reboot to see the device. Truly we lived like cavemen.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671545
i am not confused at all. the OP of this thread is using an HP motherboard so it doesnt surprise me they would only have limited availablilty for different things and using the USB 2 and 3 headers depends on your case. most cases today only use the the 19 pin headers. the low end budget ones like the cases costing under $100 for the most part would still use them as my apevia x hermes case did but my new corsair 1000d case doesnt and actually has plugs for the type c ports on the front.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671559
You were specifically arguing that 9 pin header were ONLY for RGB, they are not, and continued to insist that they were only for RGB, which they are not. 9 pin internal USB 2.0 headers are full USB 2.0 implementations which include both power and data. In fact, it's that very USB 2.0 data stream that connects RGB products to the motherboard. When I had my Wraith Prism cooler in use I found that the RGB header controls for it were sorely lacking, but the RGB controls offered when connected to an internal header were much MUCH much better. I lacked enough internal headers for all of my front 2.0 ports and the Wraith cable so I got an internal hub to split one 9 pin it 2 9 pin to service 4 ports on the front of the very very old (like from 2005) case that I'm using so I could connect the heat sink RGB to the motherboard 9 pin, it didn't like being on the hub for some reason but printers, mice, usb drives are Ok with the internal hub. Odd but ok.
Anyway, here's the pinout for both headers side by side. Each is basically 2 ports next to each other but broken out to pins. A 9 pin header services two USB 2.0 or 1.0 ports on a front panel with the 10th pin being absent for alignment, both ports share a common ground pin. USB 3.0 is setup similarly.
https://linustechtips.com/topic/1329681-9pin-usb-port/#findComment-14671595
