I9-9900K Cooler
ATK422
Setup
CPU: Intel I9-9900K [BCLK 100.80]
GPU: Gigabyte RTX 2070
MB: MSI - Z390 Gaming Pro
Memory: G.Skill - Ripjaws V Series 16 GB DDR4-3200 [XMP]
HDD: WD - Caviar Blue 1 TB 3.5" 7200RPM
SSD: SanDisk - Ultra 3D 500 GB 2.5"
M.2: Samsung 970 Evo Pro
Moniter: Asus - VG245H 75Hz
Moniter: Alienware - AW25148H 240Hz
VR: Valve Index
location?
https://www.amazon.com/ARCTIC-Liquid-Freezer-All-One/dp/B07WNJCVNW/
Arctic liquid freezer 2 series is well received.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
3 minutes ago, Mister Woof said:
location?
I currently have the 120mm one of that but it really doesn't work too well for me as I have spiked up to 97c before and whenever playing games average 80-90c
Setup
VR: Valve Index
11 minutes ago, ATK422 said:
i think that will be great i have the 240 one and the idle is 47C and the max i have seen is 74C on my 10700k
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
I was planning to buy the X73 360mm or the X63 280mm, which one do you think would be better?
Setup
VR: Valve Index
the x63 should be fine . are you planning to overclock and if so what speed
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
120mm is gonna suck no matter what brand, though
If I was to overclock it would probably depend on good how hot it gets at base clock
Setup
VR: Valve Index
True
Setup
VR: Valve Index
There are thicker 120mm's that should be fine and can be a decent option depending on the case and mounting. The Liquid Freezer II 120 is an example.
That being said, a larger rad is usually better.
What case and cooler are you using? Are you using default motherboard settings?
The X73 is better.
  • 2 weeks later...
NH-D15 all the way - run them in my home and work rig (both using i9 9900kf). You need to be careful with RAM height but a super cooler.
Intel i9-13900K - Gigabyte Aorus Z790 Elite DDR4 - Corsair Vengeance LPX 128GB DDR4 3200 C16 - Gigabyte Aorus Master RTX 4090 24GB - Corsair 4000D Airflow - 2x Samsung 980 Pro 1TB  - Corsair AX1600i 80 PLUS Titanium 1600W - Aorus FI27Q - Noctua NH-D15 running 3 fans (CPU) - 6 x NF-A12x25 (3 intake, 3 exhaust) - Aorus K1 - Aorus M5 - Aorus AMP500 - Aorus H5 - Corsair TC70 - Win 11 Pro
