Gigabytye GTX 1050 ti (GV-N105TD5-4GD) No signal
Solved by YellowBird,
So this is SOLVED now and here is what I did:
- Removed 1050 card
- Plugged monitor up to onboard video
- Booted into BIOS and turn primary to onboard and turned onboard to "always on even when secondary card is found"
- Put the 1050 card in but left monitor plugged into onboard (the only way I can see anything on the monitor)
- Booted into windows safe mode and ran ddu and turned off automatic updates
- Rebooted into windows, downloaded an installed the latest Geforce driver (drivers only)
- Shut down machine and switched monitor to 1050 card.
- I still could not see anything on the bios screen at all but once windows loaded the image appeared
- Reattached monitor to onboard and booted into BIOS and set primary to PCI Express but left the onboard to always on
- Rebooted and I had a signal all the way from BIOS to Windows
- Once inside windows I disabled the onboard display adapter
Seems to be working now and hopefully it stays that way (because it was working before as well). Thanks for your response!
