Cooler for i7 9700F
Doug_Dangger
That doesn't require me to remove the motherboard.
I completed my build.  So far the highest temp I'm seeing with the Intel cooler is 68C.
That ok with the crap stock cooler?
I'd like to get a better cooler but not willing to rip out the board for the bottom brace.  Any recomendations?
Up to $30.
yes
Up to $30.
If that's what you're getting after a few minutes at 100% load, yeah that's great.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
