POSSIBLE BUILD for 1000$
Solved by Somerandomtechyboi,
6 hours ago, Shailesh Vats said:R5 7600 - 18150
Msi B650m-a -16250 / b650m-hdv -13450
Lian li 205m - 4850 /
Gskill flare - 10600 /
3080 - 31400 /3070-19000
Kioxia exceria -5690
Ant Esports FG850 -5100
Some confusion i still have
The mobo
Gpu ,ram and the cabinet
b650m-a has better i/o but the hdv is still noticably cheaper so unless you need wifi id just pick the hdv
rams are just fine 6000c30, if 6000c32 is cheaper go for that
gpu is pretty much what you can afford, if you can afford a 3080 sure go 3080, if a 3070 then just go 3070
