Case Fans RGB Connection issue
VishnuSivadas
I used cooler master 360 mm liquid cooler and the RGB hub I got with it is not compatible with the Antec case fans. The plug is thicker and the socket is small. Is there a way I could fix it.
This is my pc configuration
1. Intel i9 10900k
2. ASUS Prime Z490-A
3. (Corsiar Vengeance DDR4 3600MHz) x 4
4. ASUS TUF GeForce RTX 3080 10GB
5. Samsung 970 EVO Plus 1TB PCIe NVMe M.2
6. Seagate Barracuda 2 TB 7200 rpm
7. CORSAIR AX-1000 WATTS SMPS Fully modular
8. Cooler master 360MM Liquid Cooler
9. LIAN LI PC-O11 Dynamic Rayzor Edition Mid-Tower ATX
10. Antec Prizm 120 ARGB Fans (6)
Also I would like to know is it fine to use the pc with out case fans (Just for few days) with the case open and with air conditioning.
The Antect has standard connector. CoolerMaster uses the mini. There are adapters, they might even come in package for AIO/hub.
As for running without fans, try and see. There's no universal answer. Too many variables.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
