An R5 3600 and RTX 3080?
I know for the most part current gen CPUs don't bottleneck GPUs that easily but..
I'm making a build and thinking of getting a Ryzen 5 3600, I'm getting a temporary Gigabyte 960 2GB OC (USD $114) till I can get my hands on a 3070 or hopefully 3080 in a year.
But I'm wondering if the 3600 will bottleneck a 3080?
I will be gaming in 1080p 144Hz most probably, but I need the 3080 for 3D work such as on Blender/Maya/3ds Max or Houdini for real-time renders in the preview window. I am also a filmmaker so Premiere Pro/Davinci Resolve is a thing, might get a 2nd 1440p/4k 60Hz panel for that.
Apart from the bottleneck problem, I just realized that I was going with a 650W power supply.. So I assume I should rather go for the 750W Bronze instead with the GPU upgrade in mind?
TL;DR - What CPU should I get for an RTX 3080 instead of the R5 3600 that doesn't break the bank too much, IF it will bottleneck.
EDIT: Forgot to add that I would also love to stream on twitch as well with this system
Edited by Avoke
the so called bottleneck is heavily defendant on what games are you using,
rather than going Ryzen 3600 which around 220, why don't you spend a bit more for Intel core i7 10700F for 250$, you got additional 2 core for your workload,
Paired with some good Value B560 Board, like AsRock B560 Steel Legend or Asus Prime B560 Plus which cost 120$, You can put some Memory Overclock on higher speed memory, and unlock the power Limit, and enjoy 4.6 all core boost on multicore workload on cheap price
My main go-to game is Dota 2, BUT that's nothing I'm worried about because it's not that resource intensive, my current i7-8750H and 6GB 1060 laptop runs it fine. Even games like Valorant can easily use the 144Hz on this system... But I'm talking about games like Warzone, upcoming Battlefield, Apex Legends, occasionally singleplayer games like RDR2 or Assassin's Creed Valhalla on max settings. Can always use more power for Minecraft as well hehe, would love to play it with RTX.
As for overclocking.. I really don't want to go in that territory.. I want a more efficient system that runs cool and quiet. Idk much about overclocking and there's a problem with claiming warranty on parts in my country, shopkeepers love to avoid it. And I thought AMD was supposed to be the cheaper alternative to Intel and I also love what they're doing as a company so wanted to switch
EDIT: Oh I forgot to add to the original post, I also want to stream with the system to twitch.
Edited by Avoke
if you just wanna save some bucks, you can go with 10400F, or newer 11400F, this will set you back 6/12 thread, otherwise 10700F is the great value 8/16 CPU
AMD price has increase now they have the performance lead on the 5000 series, while also suffering the same shortage that most GPU do, since AMD are outsourcing their production to the same factory that make those chip
11400F is better buy in this price range if you need board and EVERYTHING but if you plan to get a 12core or more later the Intel platform maxes out at just 10-cores and then you gotta go a generation backwards... UwU
Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600, 6-cores, 12-threads, 4.4/4.8GHz, 13,5MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1, A2, B1 & B2: DDR4-2666MHz CL13-15-15-15-35-1T "Samsung 8Gbit C-Die" (4x8GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Zen-II-X6-3600+ (Gaming PC)
R23 score MC: 9893pts | R23 score SC: 1248pts @4.2GHz
R23 score MC: 10151pts | R23 score SC: 1287pts @4.3GHz
R20 score MC: 3688cb | R20 score SC: 489cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35MB cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2607MHz (T.S.M.C. 7nm FinFET) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A2 & B2: DDR4-3600MHz CL16-18-8-19-37-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
I personally stream too on twitch on 10400f tho not that often, but I use Turing Card so the GPU encode is doing the job for me, it rarely have any problem, if u edit, the extra 2 core from i7 may come handy, or if u just be patient 6 not that bad
Here's the thing, I don't know if I need more cores? Do I?
I think I need good single-core performance but also 6-10 cores, but I also want a CPU that can pair well with an RTX upto 3080. Maybe in the future I do shift to very many more than I need cores like 12 so who knows..
So what I'm getting from all this and a bit of my own research is that.. An 8/16 would be best for me. So what's the best value for money 8/16 CPU that won't bottleneck a 3080?
I think 6-cores is enough for 60fps this whole console generation, tough 8-cores if you wanna make sure 100% despite the console having 8-cores the 6-core on desktop runs much higher GHz! ^_^
I would be fine with 6-cores if I was only doing gaming etc, but I'm also interested in 3D work and VFX which can definitely use the extra cores when working in software
6 to 8 gets my vote.
It’s less about being a bottleneck and more about the multitask
GPU can do the encoding but u might add plugin here and there on your stream, like those fancy chat window, your facecamera, your fancy bits reader, or idk u might have something more, additional core can help do the work
