Compatibility cpu and power supply
Almiro
hey guys , so i am planning on changing my cpu and motherboard  , i already confirm the compatibiltiy between the cpu and the motherboard but my problem is bc i dont know if my power supply is compatibly (already check the mb site and isnt there) and i was wondering if you could help on that one .
So i have at the moment a cooler master masterwatt lite 700w mpx-7001-acabw-eu and i want to know if is compatibel with a MPG Z390 GAMING PLUS ( the new mb i will buy ) .
 my specs( will be ) :  nvidia gtx 1060 3gb
                                   Intel Core i7-9700K
                                   16 gb ram
                                   3 fans on my pc and then the intel stock cooler .
And then a hyperx keyboard and headphones , asus vg245h ,rog gladius 2 . (idk if it matters bc the power usage)
It’ll work fine, psus and motherboards follow the same ATX connectivity standards.
ie same 24 pin, same eps 8 pin, same pcie 6/8 pins, etc
your choice of motherboard and choice of power supply are rarely ever a concern together
I don't see why not. If the PSU was working before and wasn't making weird noises, it shouldn't be a problem.
Fuck you scalpers, fuck you scammers, fuck all of you jerks that charge way too much to tech-illiterate people.
Unless I say I am speaking from experience or can confirm my expertise, assume it is an educated guess.
Current setup: Ryzen 5 3600, MSI MPG B550, 2x8GB DDR4-3200, RX 5600 XT (+120 core, +320 Mem), 1TB WD SN550, 1TB Team MP33, 2TB Seagate Barracuda Compute, 500GB Samsung 860 Evo, Corsair 4000D Airflow, 650W 80+ Gold. Razer peripherals.
Also have a Alienware Alpha R1: i3-4170T, GTX 860M (≈ a 750 Ti). 2x4GB DDR3L-1600, Crucial MX500
My past and current projects: VR Flight Sim: https://pcpartpicker.com/user/nathanpete/saved/#view=dG38Jx (Done!)
A do it all server for educational use: https://pcpartpicker.com/user/nathanpete/saved/#view=vmmNcf (Cancelled)
Replacement of my friend's PC nicknamed Donkey, going from 2nd gen i5 to Zen+ R5: https://pcpartpicker.com/user/nathanpete/saved/#view=WmsW4D (Done!)
CPU's typically aren't the thing you have to worry about when it comes to power drawl. Most desktop chips are going to use around 65-125w tdp.
Compatible? Yes ofcourse.
I recommend getting a better quality PSU at a lower wattage like 500w.
That PSU is pretty basic, try CX550 or Antec NeoEco Zen 500.
-> Moved to Power Supplies
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
