surround Quick 2.1 vs 5.1 Surround Sound Audio Question
Solved by Levent,
Just now, SamtheMan101 said:Even 7.1? lol I didn't know that. The motherboard diagram doesn't quite show where each surround sound connection goes to. Is there a universal diagram or something I can reference when it arrives?
RS > Rear or side.
CS > Center and subwoofer.
L-Out > Front.
L-In > Rear or side (for 7.1 audio, you have to configure it in software).
Mic > Microphone (although it also most likely can be also re assigned in software).
