Micron GDDR6X Operating Temperatures (Conflicting Info)
Solved by -rascal-,
39 minutes ago, fransarj said:Getting confused here. According to Igor's lab, Micron G6X has an operating temp of 95+C and a limit of 110C before thermal throttling (I've tested this 110C to be true). However, my BIOS is showing conflicting info with an operating temp of 83C and a max temp of 91C. Who to believe??
The MEMORY CHIPS is rated (by Micron) for 100*C+, but the GPU VBIOS is set to 91*C limit before thermal throttle.
