No Audio at 75hz refresh rate with DisplayPort
danielx511
Hi guys,
I have an LG 29UM68-P monitor hooked up to my 2020 MacBook Air with a DisplayPort. I get audio at 60hz refresh rate but once I switch to 75hz, no audio.
I am using this cable:
KabelDirekt – 8K DisplayPort Cable Version 1.4 (VESA Certified, Supports 8K 60Hz, 4K 120Hz, HBR3, DSC, HDR10, DP8K) – 3 feet
by KabelDirekt Products
Learn more: https://www.amazon.com/dp/B07HL7RXKM/ref=cm_sw_em_r_mt_dp_9PAVDJF10B12SP5489JZ?_encoding=UTF8&psc=1
On 2/26/2021 at 3:23 AM, circeseye said:
im guessing its the macbook air. it not fully supporting or "maybe" a driver glitch
Yah Im not sure. 75hz works fine when I hook a windows computer up to it. Was wondering if it was the monitor or cable's fault but it's the Macbook. Cant figure out if there is some sort of work around. I can run 75hz at a lower resolution on HDMI and get audio. Just weird.
