How does TechPowerUp's 'Relative Performance' work?
Solved by Fasauceome,
They have an internal testing suite that they compare data with. Though I never trust aggregate data sites for particularly accurate data, all you could surmise is that the 970 has almost the same performance as a 570 across their specific tests.
12 minutes ago, wat3rmelon_man2 said:but has a performance of 2 TFLOPS lower?
Teraflops aren't a good indicator of overall graphics performance.
