Browser, version and OS:
EDGE must current version
Windows 10 most recent release
Steps to reproduce/what were you doing before it happened?
Click on notification bell with major delay before the list pops up on the screen
What happened?
Click the notification bell and there is a major delay before it opens. Also happens when posting a new thread. Takes forever. This does seem like a "global" forum issue to me, FWIW
What did you expect to happen?
For notifications to pop up in a timely fashion
Any other relevant details:
Wifi connection is not the greatest here, but other forums I attend dont have anywhere near this amount of latency when navigating through the forum. The reason I say latency is because I doubt it's a bandwidth issue. This is linus tech tips after all and he is a bit of a bandwidth king, so that's probably not the issue here, although mods correct if I'm wrong.
Hardware and Overclocking Enthusiast
https://linustechtips.com/topic/1307097-forum-latency-issues/
Didnt want to make it out like this is 100% a forum issue. could be something else, it may very well be an issue on my end, perhaps. But like I said, I dont seem to have the same problems with other forums I attend.
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14494048
Try with Google Chrome or Firefox
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14494423
used to be the case with me, its now resolved, but the entire 2020 the forum was unbearable for me, idk if it was my ISP issue or DNS issue, but its so much better now, still editing comment is choppy
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14495873
I would assume a DNS issue, try changing it to googles 8.8.8.8 or cloudflare's 1.1.1.1
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14496485
16 hours ago, colonel_mortis said:
When things are loading slowly, is https://linustechtips.com/cdn-cgi/trace also slow? And is this a permanent issue, or just sometimes?
That link is not slow at all. Then again its plain text so someone on 28.8K would probably load almost as quick(maybe 30 words or so. If you have some graphical stuff on the website or the actual server, it might help narrowing it down.
It's been permanent for a couple years- since I've joined. In all likely hood I would be much more active on the forum if the website responded quickly..
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14502870
Could be your plan,infrastructure or ISP.
I live on the other side of the globe in Europe and everything loads instantly,everything is snappy to me.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14502901
If that link isn't loading then the problem is either your browser, your connection to your ISP, or your ISP's connection to Cloudflare's network, because that page is served from Cloudflare's servers and doesn't touch the forum. Can you try a different browser to rule out the first option, and try tethering to your phone to rule out the others?
HTTP/2 203
https://linustechtips.com/topic/1307097-forum-latency-issues/#findComment-14506430
