Will my Seasonic 500W Core GM work with Stepped Sine or i need Pure Sine Wave UPS ?
11 hours ago, Letgomyleghoe said:Just because a UPS doesn't make sense for you doesn't mean it don't for other people.
No, that's the wrong way round actually; just because a UPS makes sense for you, it doesn't mean it also does for other people.
You make it seem like I'm against buying a UPS, or something like that, because I don't use one myself, which just isn't true. I only pointed out that most people don't need one, and that therefore suggested the OP considers if they really need a UPS.
13 hours ago, jonnyGURU said:It comes from the idea that the square wave has a higher RMS voltage that exceeds the bus voltage of the PSU. But this actually causing a problem is extremely rare.
The RMS voltage is the same, but the voltage is quite a bit higher than with a regular sine wave at certain points in time.
I don't know how exactly that affects computer power supplies, but I do know that it can cause some weird effects on other electronics. It's also not recommended to run motors/transformers on square waves due to increased heat production and therefore worse effciency (but probably no damage to anything)
