CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£161.99 @ Aria PC)
Motherboard: Asus H81M-PLUS Micro ATX LGA1150 Motherboard  (£40.57 @ Scan.co.uk)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  (£51.58 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  (£47.99 @ Aria PC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£51.98 @ Aria PC)
Video Card: MSI GeForce GTX 770 2GB Video Card  (£238.04 @ Aria PC)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£32.99 @ Novatech)
Power Supply: OCZ ZT 550W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£62.98 @ Amazon UK)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive  (£10.78 @ Scan.co.uk)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  (£69.96 @ CCL Computers)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£12.00 @ Amazon UK)
Total: £832.44
Can anyone give advice, based on these specs? I won't be overclocking, and the PC is being used for gaming, as well as recording/editing/rendering videos.
---Jacob Whitehead---
https://linustechtips.com/topic/130343-my-first-build-need-advice/
Looks good
  • Only 8gb
  • Better PSU
  • Better Case
Good Luck
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
Personally I'd swap out that OCZ PSU as I've read horror stories about OCZ PSUs. Go for a quality brand PSU like Corsair, Silverpower, Seasonic, Enermax or something along those lines.
I'd also throw in a  CPU cooler in there like the Cooler Master Hyper212 evo for exmaple as it's not very pricy and offers great performance for its price.
also for the Ram, see if you can find a kit instead of buying 2 separate sticks, while it might not matter but the kits are made to work together.
also makes me wonder if that ATX PSU will fit in a Micro ATX case, but i havent seen it.
Proud Member of the Glorious PC Master Race
https://uk.pcpartpicker.com/part/intel-cpu-bx80646e31230v3, as you are not getting a z87 oc capable board anyways, you might want to step up to a more optimized cpu option for a non oc usecase.
https://uk.pcpartpicker.com/part/kingston-memory-khx16c9t3k216x, to make sure the memory works at it rated speed and stable.
https://uk.pcpartpicker.com/part/corsair-power-supply-cx600m, its just a higher quality psu, compared to the ocz.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
