USB devices keeps disconnecting randomly, have to reboot PC to get them running again
Solved by mkN1G,
Hello again guys, I am happy to inform you that the problem has been solved and you will never guess what it was!!
I was about to go to the store with my friend to buy a new PSU, but before that I wanted to show my friend how the problem occured. Nothing happened to the K70 when I plugged it in the PC, tried my laptop and I got the same error message that there isn't enough power for the USB ports. And by accident I found out that it was a faulty cable in the keyboard, it was kinda loose. That's what made the other USB devices disconnect, the K70 must've short-circuit the other devices.
I am typing on my new K70 MK.2 atm and I am quite happy that I didn't waste money on a new PSU!!
