GPU fan headers vs chasis headers
Solved by narrdarr,
I agree that relying on software is may not be the best, but you could do it. And if I were to use software I'd use fancontrol.
Bios cannot be set to read GPU temp.
Other options would be
-use an offset fan curve based on cpu temp.
- get a corsair commander pro. Which is an independent fan, rub, and thermal sensing controller that you can use to set fan curve based on any sensor.
- best option would be to use the crj splitter to connect the fans to the GPU.
