Monitor screen darkening issue
Epiccc
Sounds like ghosting (slow dark transition speed), VA panels suffer most notably from this.
There is no absolute fix, its a flaw in the technology.
Only the Samsung Odyssey G7 has been able to design a VA panel fast enough to avoid this issue in its entirety.
However, ur display, the Dell S3220DGF, is one of the better VA monitors, one i often recommend.
Find the overdrive setting and set it to 'super fast'. This should help a lot, but wont clear it up entirely.
'Extreme' may well get rid of it almost entirely, however it will introduce 'overshoot' artifacts (inverse ghosting), which can be more noticeable than regular ghosting.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
