I would advice against putting magnets inside the case. Though only HDDs will have major problem with them. If you must, rather use some double-sided tape.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1295845-pc-case-question/#findComment-14406186
or velcro
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1295845-pc-case-question/#findComment-14406190
5 minutes ago, Xarai said:
So I recently completed my first build and wanted to decorate my rather plain PC case. This might sound like a stupid question but; Is it safe for the internal components if I place magnets as a form of decor on the outside of my case?
As always - it depends...
Small fridge magnets (I mean these thing which mostly look like rubberized pads) on the outside especially opposite to the Mobo and not in direct proximity to HDDs - shouldn’t be a problem at all.
I wouldn’t use any magnets inside the case so – especially if they might fall and contact/short something inside – but on the outside – see above…
Best regards,
Medizinmann
https://linustechtips.com/topic/1295845-pc-case-question/#findComment-14406216
It should be safe.
A magnet that size won't effect any of the hardware inside (even HDD).
https://linustechtips.com/topic/1295845-pc-case-question/#findComment-14406257
27 minutes ago, Xarai said:
Oh, I meant to say outside the case. Edited last minute sorry
Should be fine if the magnets aren't diabolicaly strong. My case comes with magnetic dustfilters and magnetic panels. I just hang them on the side of the case when I swap. No problem. If magnets are strong I wouldn't have them anywhere near the hard drives but I doubt you'll be using such strong magnets anyway. Just thought I'd mention that.... 😛
https://linustechtips.com/topic/1295845-pc-case-question/#findComment-14406292
