First of all, you would probably have an easier time getting assistance if you made your thread title something descriptive about your actual question, someone posts a thread titled "HELP ME PLEASE" or some variation thereof (but invariably in all caps) at least once a day.
Now then. There are multiple different computers sold under the HP ProDesk 400 G4 name.  The small form factor ones aren't going to be compatible with any GPU because none will physically fit inside. The "microtower" ones like this are large enough to hold a modest GPU and have PCIe x16 slots according to the manual, but the issue would be the power supply - I can't find the wattage listed anywhere but I imagine it would be very low and the unit probably wouldn't have any PCIe power connectors.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1294077-pls-help/#findComment-14393345
1 hour ago, Hiraa PtoGamer said:
I need a PC for stream/Gaming/Editing then i found a renewed PC in amaazon for a good price it is a HP ProDesk 400 g4 and it just does not have a gpu and i dont what is compatable with it so pls let me know what is the GPU
dont go for pre build build a custom one can you tell me your budget so i can suggest you some parts
https://linustechtips.com/topic/1294077-pls-help/#findComment-14393421
5 hours ago, Hiraa PtoGamer said:
My budget is 550 USD
for the cpu and gpu and mobo you would have to go to the used market the prices below are for thr used parts
for the mobo get any 3rd gen intel mobo it would cost you 19$
580+19$ for the mobo
in total 599$
https://linustechtips.com/topic/1294077-pls-help/#findComment-14393449
in total 599$
Ddr4 memory for an ivy bridge cpu. Interesting.. 😂😂
Also why to spend money on such old platform.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1294077-pls-help/#findComment-14393528
