Over the past couple months, I've been looking at different build and consulting this forum for ideas and I think I have finally come to a final build. I'm looking at using a Ryzen 5600x paired with an MSI RTX 3070 Gaming X Trio (When it comes back in stock at msrp((yes, I know that will be a while)). Comment your opinions on it below.
https://pcpartpicker.com/user/Genericbot1/saved/Ryw4sY
NOTE: I'm reusing a 2 TB hard drive so overall I'll have 3 TB of storage which should be more than enough
https://linustechtips.com/topic/1293486-how-does-my-build-look/
Looks really good to me. Only thing I'd personally change is adding a 1-2 TB HDD along with the SSD. I personally like having a second drive to go alongside my boot drive. Then if I have any games I don't care about fast load times on I don't have to worry about them cluttering up my boot drive. And it's nice having a second drive to keep backups on in case anything were to somehow happen to your main drive.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389103
Please use the mesh case not the one with plastic sheet in front of the fans. It was made fun of right after it launched and for good reason. Adding ARGB to it does not improve thermals.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389106
Just now, Adkatka said:
Hmm... It is not that bad, but CPU and GPU is out of stock.
and.. 100$ Windows 10... home...
AMD has been dropping new 5600x stock consistently. The problem will be getting the GPU. I'll probably just reuse my old GPU until the Gaming X Trio is back in stock.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389109
OP is aware of this, as mentioned in their post
What's wrong with Windows 10 Home exactly? I've used both home and pro before and I don't find that the differences matter that much for general use (gaming, school, web browsing, etc).
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389111
I actually forgot to mention that I'm reusing a 2 TB hard drive from my old pre-built. I agree with everything else.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389112
I actually like how the mesh looks more than the transparent front panel. it looked eh and of course, bad thermals.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389118
Just now, WaggishOhio383 said:
What's wrong with Windows 10 Home exactly? I've used both home and pro before and I don't find that the differences matter that much for general gaming use.
I think hes more talking about the fact you can get keys for windows for like 10 on the grey market. I personally wouldn't but Idc if others do.
Chicago Bears fan, Bear Down
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389119
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389120
Well in that case I guess you're good
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389125
7 minutes ago, HairlessMonkeyBoy said:
Thanks, but I like my build more though I will look for a NVMe instead.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389139
2 minutes ago, ragnarok0273 said:
7/10.
-2 - no optical drive
-1 - aftermarket card over FE card
Quick note I am reusing a two TB hard drive from my old PC. Also founders edition cards are close to impossible to find and probably will be like that forever. Thats just what Nvida does
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389145
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389146
My personal preferences - your build looks great except I would try and get NVMe over SATA.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389149
No worries. I assumed it'd be academic.
For a 1TB drive this seems to be the best value at the moment. TLC NAND with DRAM cache:
https://pcpartpicker.com/product/JHxbt6/mushkin-pilot-e-1-tb-m2-2280-nvme-solid-state-drive-mknssdpe1tb-d8
This one will do, but does not have DRAM cache, so it's quite a bit slower.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389152
why would you need an optical drive anyway? It is not a must-have since 2012...
Optical drives are handy, and I've always deducted 2 points on any build review.
I usually say "ignore the optical drive part" but I guess I didn't this time? 9/10.
Oops.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14389155
yeah its good but windows 10 home??? i would advise to go with pro
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14390493
I don't really have any need for it seeing as I'm not anywhere near needing a work computer. Plus, I have an old prebuilt and windows 10 home has pretty much all of the features I need so that's why I passed. Also windows 10 home is cheaper and it's a way to cut costs and fit better hardware into my budget.
https://linustechtips.com/topic/1293486-how-does-my-build-look/#findComment-14392855
