PHP help (again)
Go to solution Solved by mariushm,
You can use fopen and fread and fclose  or you could just use file_get_contents and file_put_contents
Something like this
<?php
// __DIR__  is the folder where this script is saved
$path = __DIR__ .'/forbidden/counter.txt';
$content = file_get_contents($path);
if ($content===FALSE) {
	die("Fail: file $path not found.\n");
$value = intval($content);
$value++;
$result = file_put_contents($path,$value);
// output something here if you want to
// header('Content-Type: application/vnd.api+json');
// echo json_encode(array('counter'=>$value, 'success'=>TRUE));
Need a PHP script that does this, It Finds a txt file (localhost:443/forbid/count.txt
When the PHP file is Called, it will Get the Value of the Current number lie "1" and Change it to "2", "3", and so on.
How can i go about this?
Running PHP 7.4 with Apache (and the PHP file will be called from a javascript ajax request)
https://linustechtips.com/topic/1290662-php-help-again/
Something like this
<?php
$value++;
https://linustechtips.com/topic/1290662-php-help-again/#findComment-14382220
