Budget (including currency): Around 3000$
Country: Czech Republic
Games, programs or workloads that it will be used for: Cyberpunk 2077, ARK: Survival Evolved, retro games, 3D graphics and rendering (Cinema 4D, Blender, SketchUp, Zbrush)
Now in my old PC I have these components:
HyperX Predator 16 GB DDR4 3333 MHz
AMD Ryzen 5 2600
Gigabyte B450 Aorus Pro
Gigabyte GeForce GTX 1070 Ti Gaming 8G
Cooler Master MasterWatt 550W TUF edition
Case Zalman Z1 Neo
Classic SATA III SSD 512 GB and 2TB HDD
If anyone can tell me approximately sell value of this PC (It was just 2 years this January since I build it) I would be happy, my friend tell me that this setup is worth around 1000$ but I think it is overpriced.
In my new build that I'm going to realise in mid February to March (depends on components in stocks)
HyperX 32 GB kit DDR4 3600 MHz CL18 Fury black
AMD Ryzen 9 5900x
NOCTUA NH-D15
Asus ROG STRIX X570-F Gaming
GeForce RTX 3080 Ti
Seasonic Focus GX 850W Gold
Case Fractal Design Define S2 Blackout
Samsung 970 EVO PLUS 1TB - M.2 SSD
and any casual 2TB or 4TB SATA III HDD
Hello, my goal is to build PC that I will use for gaming/streaming and doing 3D graphics sometimes (most of the time just creating models and then printing on 3D printer)
Can anybody help me with this build that I chose is good depending on my budget or if I can improve something or save some money with different components.
I don't need any RGB flashing components because my case will be under table so I'm focusing mainly on functionality.
Thanks for any help you can give me, this is going to be my second build so I want to make sure that it will be good :) And I appologize for my English mistakes aswell.
https://linustechtips.com/topic/1289972-help-with-new-gamingstreaming-pc/
AMD Ryzen 5 2600
Case Zalman Z1 Neo
AMD Ryzen 9 5900x
NOCTUA NH-D15
GeForce RTX 3080 Ti
Looks like a pretty sweet build. I wish I could afford those components 😃
The X570 probably is overkill though...a B550 will work just fine.
Good build.
Try to get CL16 if it falls in your budget.
You can save a few bucks by not getting Samsung nvme and similar performance from other brands.
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
8 minutes ago, boggy77 said:
your current build is worth around $600. i bought a nearly new pc a year ago with a 2600x and a 1660 for £550.
as for your future build, looks good. to save some money, go for the b550 version of the board.
Thank you, that is more real sell price :) And for B550 you recomment Pro or Elite version? Or it doesn't matter?
Isn't X570 better for potencional future upgrade or they are similiar?
from msi's website:
"Some professionals may need even more power and extensibility than what the B550 platform can offer. For such professionals, MSI’s X570 motherboards are the ideal choice. If any of the following apply to you, the X570 platform is a better choice:
You use more than 4 USB 3.1 devices
You use more than 6 SATA devices
You use more than 3 Gen 4 M.2 SSDs"
So unless you need any of those, you're fine with b550.
I was talking b550 strix-f. but there are many other good b550 boards, like the tomahawk or the aorus pro.
Not really. In my opinion they both have similar upgradeability. By the time you want to do a full upgrade, you'll probably change the MB anyways. I'm sure some others have different opinions though.
4 minutes ago, boggy77 said:
from msi's website:
Ok so I can work with B550 just fine, I don't need that much SATA or USB 3.1 ports. It will save me around 100$ thanks :)
I guess you are right B550 will be enough for me right now, thanks for help :)
X570 is generally better performance from your components but uses a bit more power, generates more heat.
A good quality B550 would be my choice
You'll get about $300 for your 1070ti on ebay
You'll get about $150 for the cpu
maybe $70 for the ram
$50 for the motherboard
the other stuff is basically not worth selling.
I wonder how much I can get for my 1600af...I was one of the lucky ones to find it at $85. They go for $169 (new) on newegg right now. 🙄
I've been itching to upgrade to a Ryzen 5 3600. I'd love to get a R5 5600, but my b450 mb is pretty low-end and I believe a 3600 would be the limit of the crap VRM's.
One more question, I heard that some motherboards have problem with Ryzen 5000 series due to BIOS update. Will B550 need BIOS upgrade with older CPU or can I use it with Ryzen 9 5900x without any problems?
get a board that has a bios flashback feature. that way, in case the board doesn't ship with the latest bios, you can update it with a usb without needing a cpu plugged in.
and this is another reason to go for b550, as most of them have this feature, with fewer x570 boards having it.
That is great feature! Thank you for the tip.
Your current build is probably worth about £600-650
As for the new one. Looks great! Maybe go for a slightly cheaper NVMe Drive like an SN550, but that is up to you.
Also, maybe look for a CL16 ram kit instead if that fits in your budget
In terms of RAMS do you know name of good ones? The ones that I can buy in my country are pretty badly jugged.
I can buy only these: G.SKILL 32GB KIT DDR4 3600MHz CL16 Trident Z RGB Neo for Ryzen 3000
10 minutes ago, Avocheeseado said:
How much are they going for??
This version is for 260$ but I'm not sure if they are only for Ryzen 3000 when they have it in the name.
Different shop has same RAMS without "for Ryzen 3000" in the name and it cost around 340$
Someone had problem that after boosting it more than 3266 MHz RAMS started causing fatal errors.
They are not for ryzen 3000 only. The cheapest 3600c16 kit will be fine.
https://www.alza.cz/search.htm?exps=cl16+3600
https://www.czc.cz/CL16 3600/hledat
These are shops that have atleast some CL16, can you take a look and recommend something? :)
