Help...Low 100 FPS on warzone with RTX 3080?
Solved by Tristerin,
Dont forget, this is ONLINE play, meaning you are also waiting on network information that the GPU then has to fetch and display on screen...every MS.
How does your system run in the single player mode if you own it? That will give you more of an ideal on how your hardware is actually working with the software.
Featured Topics
Beeswitt ·
Posted in Troubleshooting0 -
3
CrowTheRobot ·
Posted in Windows1 -
1
6
uncanny_mac ·
Posted in New Builds and Planning0
