9 minutes ago, GOJIRA229 said:
Hello I am looking for some advice on an audio equalizer for around 50$ that is easy to use and would fit in with schiit equipment
I'm told the best way to do it is with software, haven't seen hardware EQ in quite a while
Audio go Brrrrrr
https://linustechtips.com/topic/1288572-budget-audio-equalizer/#findComment-14352705
Just now, GOJIRA229 said:
Thanks for the advice do you know of any free software solutions that I could try
I don't really use an EQ myself, but have used foobar2000 for music.  It's a player with a good built in EQ but it's only for music
Audio go Brrrrrr
https://linustechtips.com/topic/1288572-budget-audio-equalizer/#findComment-14352726
Don't use foobar boomer crap nobo.
Equalizer APO. Use parametric filters only and I recommend looking to oratory1990's Harman Curve EQ's on Reddit.
https://linustechtips.com/topic/1288572-budget-audio-equalizer/#findComment-14358550
