so i recently got a Wifi 6 Router (Huawei WiFi AX3) and i also have one of xfinities modem/router combo and my wifi is faster on my xfinity router even though its not WiFi 6. is there something i did wrong? my rated download speed is 1000 MBPS. the phone im using is the iphone 12 pro max so its wifi 6 enabled so.
i7 12700k/Asus Tuf z690/32GB Corsair Dominator RGB 3200MHZ/EVGA 3080 Ti FTW3 Ultra/Samsung 980 Pro 1TB/Asus 2540x1440p 165hz Gsync/Acer 2560x1440p G Sync 144hz
https://linustechtips.com/topic/1288141-slow-wifi-6/
2 minutes ago, Electronics Wizardy said:
How are you measing wifi speeds?
Try testing on your local network instead of using a test over the internet.
im just using speedtest on my phone. my pc is plugged into the wifi 6 router and gets the full speed its just wifi that seems to be slower
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349511
WiFi 6 isn't really about faster speeds for one client, it's about better overall performance when there are many concurrent active clients.
F@H
GPD Win 2
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349519
The performance of a router depends on the effective AX spee (for Wi-Fi 6) or AC speed for Wi-Fi 5.
I have AC 3100 Wi-Fi 5,it's very fast (getting 1Gb/s)
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349520
What does the router report the PHY rate to be?
i dont even know what that means lol networking noob here
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349522
ive never obtained that, fastest ive reached on wifi is 600 mbps. but were paying for 1000
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349525
It should work the wifi connection speed in the router to get the connection speed. There are a lot of variables to wifi speed, so this helps you know what type of conenction you have. Look under list of wifi clients.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349531
That seems pretty normal for wifi, also those phones are a bit limited wifi speed, I think there 80mhz max channel width aswell.
Your paying for 1000mbit wired, not on wifi, so if possible test over your local network to remove the isp as a variable.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349534
either mine doesnt have that or i cant find it.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349536
how would i test my local network?
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349540
Can you show a screenshot of the wifi client list, and the info about the client.
Being a phone, this will be much hardware, do you have a laptop or desktop to test with?
I really wouldn't worry about this, those speeds are expected for wifi connections.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349542
well i only have my desktop and a phone. i think thats it
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349557
You need both a capable router and a capable Wi-Fi card.
I checked the specs of your router,you have fallen for deceptive marketing,
3000 Mbps is the effective speed it's not the true speed,but that number is not the actual effective speed,since they combined the effective speeds of both the 2.4GHz band and the 5GHz band,
Furthermore your router has two 2x2 systems,which lowers the effective speed even more,one of them does not support Wi-Fi 5 AC signals at all.
Also the speed depends on your Wi-Fi card as well.
What Wi-Fi card do you have?
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349563
my desktop isnt even wifi capable im going off my phone actually iPhone 12 Pro Max
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349568
The Wi-Fi in the SOC of the iPhone could be the limiting factor.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349576
that doesnt explain why the wifi on the xfinity modem is faster
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349642
What is the model number of it?
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349667
ARRIS TG3482G | Model number: TG3482G i believe thats it
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349689
Out of curiosity, how are the AX3 and Xfinity devices connected? I.e. from your 1Gbps ISP connection to your computer.
Are you using the AX3 and Xfinity devices at the same time? Are they both providing WiFi?
Please post the wireless settings of both the AX3 and the Xfinity device as you see them in the administration interface. Obviously, sanitize any private information as necessary.
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349694
i have my pc plugged into the router then the router into the modem both with eithernet, and yes they are both providing WiFi. i did try turning off the xfinity device WiFi and it didnt change anything. and both are using default settings
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14349698
So is the AX3 (which is plugged into the Xfinity gateway) running in access point mode?
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14350080
it doesnt even have that option. so its just using default
https://linustechtips.com/topic/1288141-slow-wifi-6/#findComment-14350147
