7 minutes ago, FarmerGiles97 said:
Im running around 45/55 Celsius on idle with my 5900x, and 82 degrees on a all core stress test with a 360mm aio and auto oc enabled? Is this right?
What are your temps and scores on cinebench?
Depends on what auto oc does in your case. A bit high for my taste with a 360 mm AIO. How far does the auto oc push your cpu? Generally speaking those temps for the cpu. Still, anything above 80 C on water would have my worried long term.
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348585
Your idle temp seems fine, but the load temp seems a bit high for a 360mm, but its considered safe
I would say the higher than expected temp is the auto OC pushing your CPU harder since there's still thermal headroom
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348609
When auto oc isnt on i get max temps of 72 Celsius !
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348664
That's what auto OC does, it cranks up voltage and frequency until there's no more headroom to tune up
Sounds like it's operating as it should, especially if you're getting 72c on stock settings
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348678
Thank you :) I posted a screenshot of all the monitoring software while cinebench r23 is running on multi core!
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348681
Looks normal to me, 4.4 at 81c is nice
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348722
Looks pretty fine to me considering the voltage is 1.4V, at least according to the monitoring software you took a screenshot of.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1288020-5900x-idle-temps/#findComment-14348946
