360mm AIO for Ryzen 5950x
BoberMod
I'm looking for a 360mm AIO for:
CPU: Ryzen 5950X
Case: Fractal Design Meshify 2 (link to official website)
Radiator placement: top.
As I know, there are no ability to install 420mm radiator due to frontal 3 x 140mm fans.
Requirements:
  • Relatively quiet, because case will stand on the table and the computer will sometimes work at night.
  • Copper radiator. To be honest, I did not find such AIO and not sure if I should worry about it. I want to overclock my CPU, but not to the limit.
  • RGB, but it is not critical. If the version without RGB will be more productive - don't care about the backlight. RGB should be controllable and remember the previous state so that I can turn it off freely.
Options I'm considering (but feel free to offer your own option):
  • Arctic Liquid Freezer II 360
  • Fractal Celsius S36
  • Asus ROG Ryujin 360 OR Strix LC 360
if you want the best performance: artic liquid freezer ii 360
if you want lowest noise level :fractal celsius s36
personal i would recommend the asus rog ryujin 360
5 hours ago, glenalz81 said:
I can vouch for the LF II being a great cooler.
What CPU do you use it with?
