Posted December 20, 2020 Budget (including currency): 300 dollars / 3000 NOK Country: Norway Games, programs or workloads that it will be used for: Game devloping, heavy workloads. Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Case: Phanteks P500A PSU: P850W Aorus Motherboard: MSI MPG X570 Gaming pro carbon wifi CPU: Ryzen 5 5600x GPU: TUF 3070 OC editon Ram: Corsair Vengance Pro 3600 mhz 32 gb NVMe: Corsair Force Series MP600 1tb. I've been wondering which AIO I should get in general even though being kind of skeptical about the lifespan and being kind of worried about how big a chance it is that an AIO can leak. In general, I've been thinking about the Arctic liquid freezer 360, the nzxt x73, the lian li galahad 360, or the MSI MAG coreliquid 360r or air cooling, I want to get the best performance possible in an reasonable price and good temps. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 20, 2020 Since the 5600x isn't that high end and high power of a cheap, id get a mid range air cooler, like a nh u12s or simmilar. A 212 should work aswell Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 20, 2020 Why do you need a cooler the cost of your cpu? The stock cooler on a non overclocked 5600x is "fine". Something like this will look nice and cool your cpu very well on any overclock. Instead of spending a ludicrous amount of money on a cpu cooler you can upgrade to a 3080. https://www.amazon.com/ID-COOLING-SE-234-ARGB-Cooler-Addressable-Heatpipes/dp/B084G3Y7KZ Quote me for a reply, React if I was helpful, informative, or funny AMD blackout rig cpu: ryzen 5 3600 @4.4ghz @1.35v gpu: rx5700xt 2200mhz ram: vengeance lpx c15 3200mhz mobo: gigabyte b550 pro psu: cooler master mwe 650w case: masterbox mbx520 fans:Noctua industrial 3000rpm x6 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 20, 2020 Author 13 minutes ago, Letgomyleghoe. said: Why do you need a cooler the cost of your cpu? The stock cooler on a non overclocked 5600x is "fine". Something like this will look nice and cool your cpu very well on any overclock. Instead of spending a ludicrous amount of money on a cpu cooler you can upgrade to a 3080. https://www.amazon.com/ID-COOLING-SE-234-ARGB-Cooler-Addressable-Heatpipes/dp/B084G3Y7KZ Yeah I was originally going to buy a 3080 but I managed to get my hands on a 3070, I might upgrade later on. Oh and I paid the same amount for my 3070 as for an 3080. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 20, 2020 If you have the money to spend and you really want liquid inside your rig... do your research and go big or go home with a DIY kit from EK or some other one. (34) Watercooling for Beginners 2018 - YouTube Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
