Cyberpunk 2077 fps questions
GamerBlake
Hey everyone,
I picked up Cyberpunk 2077 the day it came out and I’m wondering if anyone is having FPS issues?
Im running an 8700K + 2080 Ti and I’m barely getting by with like 65-75 FPS @ 1440p with almost max settings.
So I’m wondering if anyone with lower end GPUs are having significant issues with FPS?
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
This game is known to have lots of issues with FPS even with top tier hardware. I suggest you try newer drivers if you haven't already. Pretty sure there's a new game ready driver for CyberPunk.
The game runs smoothly at High/Ultra on a rig with i5-6500 and a GTX 1070...@1080P...so I don"t see why your fps should be so bad.
34 minutes ago, GamerBlake said:
Hey everyone,
This will be of some use.
Go to the gameplay TAB in game, set Pedestrian counts to LOW from High, still plenty of NPCs and it saves CPU usages.
Plenty of settings can be changed down for little to no noticeable changes, which will also save some CPU cycles.
Don't think that because he has a 10900K and 3090 you can't get gains.
The settings he changed he brings up Percentage gains, which carries to other GPU's (because its a percentage based cost he uses)
You can also set an FPS cap if the game is broken and this doesn't work (game needs updates) FPS caps keep the swings up and down a lot tighter and more consistent, which overall is better.
1000 Different PC's and 500-1000 different results.... because the game needs work. (Even still these videos should be of some use)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Sounds about right. At 4k with an RTX 3080 and 10700k I see around 50 - 60 fps with mostly max settings.
It's a demanding game.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I already downloaded Nvidia’s latest drivers.
I think it’s because you’re running it at high/ultra 1080p and I’m running max settings at 1440p.
Game runs smoothly on my 4790K without RTX when the game itself is Ultra. and smooth.
RTX wise, the CPU can't handle both that and 60fps in the city or in heavy scenes.
Without RTX, it's so much smoother to play.
Each to their own of course...
Ohh maybe that’s it.
I have everything maxed out for quality and RTX & DLSS enabled and set at max quality rather than performance.
So basically I’m playing the game with the most demanding settings possible. 😆
Either way though I seem to be getting by OK with ~65fps. Sure it’s not as great as 144fps but it’s not like there is stuttering and freezes and stuff like that.
Heck don’t/didn’t most consoles run at 30/60 FPS? I figure if people can play consoles at 60fps I shouldn’t really complain about 65fps.
Plus I know I’m lucky. Not everyone can afford a 2080 Ti or a 3000 series card.
I feel bad for the gamers who are running GTX 760s and similar GPUs. Heck I was playing WoW last night with a guild member who is still using, no joke, a GTX 680,
Alot of people have attributed some game instability to RTX being on so probably going ahead and disabling it until some big patches come out would be certainly worth it. I bought the game Friday and refuse to open/play it until much of the bugs get patched out. Until then more Witcher 3 :)
SPEC LIST:
CPU: AMD Ryzen 5 2600x w/ AMD Wraith Stock Cooler
MOTHERBOARD: Asus ROG Strix B-450F
RAM: Corsair Vengeance Pro RGB 32gb 3200mhz (2x16gb)
GPU: Nvidia RTX 2080 Super FE
PSU: Corsair 750x 80plus Gold
FANS: Dual Corsair LL Series LL140mm Dual Light Loop RGB
MONITORS: BenQ ZOWIE XL2411P 24 Inch FHD LED 144Hz (DP)
Lenovo - G25-10 24.5" LED FHD 144HZ Monitor (HDMI)
PATIENCE: NOT CURRENTLY INSTALLED
P.S: STILL REALLY WANTING TO FIND SOMEONE WHO CAN CARRY ME TO GRAND CHAMPION IN ROCKET LEAGUE :)
P.P.S: I NO LONGER NEED TO BE CARRIED TO GRAND CHAMPION AS I HAVE MADE IT ON MY OWN 😁
On 12/14/2020 at 5:22 AM, GamerBlake said:
Hey everyone,
I have an 8700k + 3080 @1080p. Maxed out I get a similar FPS to you. To be honest I think we're CPU bound as I should be getting much better perf with a higher end CPU.
i run a 8700k + 3080 and 32gig and 1440p maxed out with RTX, although at Quality DLSS, runs like a charm..
i get that the game has visual defects, and people seem to be steaming about it, in a way that if you like the game, then you are stupid...
i must say i have loved the game for the first 10 hours of gameplay, no crashes.. i have had the odd visual defect, like cigarettes hanging in the air when talking to Johnny, and a wierd "call of my car" that just went beserk in an area... but it has not been that bad for me.. i might just be lucky, i simply love the game, and it runs great, it should on my system i get it, but no wierd pacing, or hickups.. just runs, and looks just soo insane fidelity wise.
and must admit i for once feel the difference between RTX on and of is big. even though i am DLSS running the game on quality level.
On 12/15/2020 at 9:08 AM, TheDataAnalyst said:
Well can't say for sure cause you are doing 1440p, but I'm getting around 180 FPS running 1080p with Ray Tracing Ultra. I could go to 1440p on Ultra i'd assume get 140-150s. I actually think it could be your CPU holding you back not the 2080TI... Assuming you are not running some insane Ultra settings.
i7 10700F / RTX 3070 / 80 GB 3200 RAM
Thanks for the info!
I have everything maxed out and enabled and when possible set at “quality” as priority over “performance”.
The only thing I have disabled is “motion blur” because Linus said in his “Cheap vs Expensive Gaming” video that “it’s stupid.”
Here are the settings I’m using at 1440p.
The part of the game I’m at now is giving me about 30fps now. Which kinda sucks but the gameplay experience isn’t too bad and I’m not getting stuttering or anything which is great.
I think I can agree with that.
I mean I understand why the game is so demanding. The graphics are insanely good and there is constant activity in the city and the CPU has to do all those calculations for every little thing.
The 3080 is an amazing GPU that makes me regret getting a 2080 Ti.
If had known a 3080 would be about 10% better at half the price I would’ve waited.
Then again finding one in stock is nearly impossible and then greedy people are buying them up to sell for twice the price which is something I just cannot support or take part in.
I think the 3000 series is great because it’s not like a huge bump in performance compared to the 2000 series but Nvidia was able to drop the prices to more affordable levels.
Like people who couldn’t afford a 2080 can now buy a 3070 for much cheaper and get similar performance.
I’m glad to hear the problem isn’t just my PC but is the game itself. Hopefully some patches are released to optimize it better.
Thanks for your input! I appreciate it. :)
Sounds like your rig is basically the same as mine.
We both have an 8700K (mine is OC’ed to 5GHz all cores) my 2080 Ti is pretty close to your 3080 in terms of performance (about 7% less in some things at double the price), and we both have 32GB of RAM (mine is OC’ed to 3600 MHz).
Are you running it on an NVMe SSD?
I have the game installed on my 1TB Samsung 970 Evo Plus.
Not an official patch but maybe this helps you in some way (there have been mixed reports about the success of performance enhancements, results may vary)
https://github.com/yamashi/PerformanceOverhaulCyberpunk
Disclaimer: I can't afford CyberPunk or a PC that can run it, so use at your own risk :)
the 3080 is quite a bit faster, especially in RTX performance..
running the 8700k at stock, and running on an SSD i believe it is running from an normal SATA SSD, i do have a SN750 drive in my pc... but also a lot of normal SSD´s but have never felt any performance difference between SSD´s in games.. SSD vs HD is something completely different.
my 1080ti in my son´s pc seems to run it great too, but at lower resolutions..
