CPU AMD ryzen 9 5950x
Cooler is noctua NH-U12A
New PC is done an i am very happy with the result BUT...
I am unsure about the temperature of the CPU
When the PC as no task
When i game
When i use software like Adobe Premier Pro
Sometime  i have temerature spike up until 83 celcius and am doing nothing on the PC
Fans are PWM
Could use some help
https://linustechtips.com/topic/1279141-pc-temperature-average/
That's not good. What case do you use, and what fan placement is set?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287290
The NH-U12 is not enough to cool a 16 core processor.
Go for either the NH-D15/NH-D15S or a liquid cooler.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287308
Or if one has the room (in the case) something big like an Scythe Ninja 5 or equivalent.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287316
Even with that cooler idle temps shouldn't be hitting 83, OP said he was doing nothing with the computer.
You didn't leave the protective plastic on the plate of the cooler did you :P I've done it before :P
Still for that CPU I'd get a 280mm AIO water cooler.
CPU - Ryzen 7 5800x3D |  GPU - RTX 3080 TUF OC | Motherboard - ASUS TUF X570 | RAM - Patriot Viper Blackout 32GB 3200MHz | Case - InWin 805 | Boot Drive - Corsair MP600 PCIe 4.0  Storage - 2 x 1TB SSD's & 1 500GB SSD | PSU - Seasonic Focus Gold 1000w | Display - ASUS TUF VG27WQ Curved 1440P 165Hz | Cooling - ASUS TUF LC240 AIO + 5 aRGB Fans
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287336
Windows 10 likes to make sure that the PC is not idle :D
It also could be the thermal pastes and mounting pressure,
For OP: What thermal paste did you use?
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287349
No i didnt :)    You can see for yourself
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14287569
Have you tried ryzen master or any other software to measure temps? HWmonitor can sometimes give false readings with AMD.  Have you looked in bios to see cpu temps?
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14291123
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14291138
1 hour ago, Voluspa said:
What would you recommend for a cooler replacement?
Liquid cooling or air cooling
What brand?
I don’t care about RGB, all I want is a very efficient and reliable cooling system.
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14291314
I’ve just installed Ryzen master, thank you for the advice. As for the CPU temp in the Bios, I didn’t really check. By the time i check the temp in the BIOS, it might just go down, what do you think?
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14291322
The readings in bios should give you at least an idea of the idle temps, I thnk it depends on the bios/motherboard but the cpu might run at full speed in bios anyway (full clock speed, not full load)
Another option is to manually test the temps with an IR heat gun thermometer or probe or thermocouple. They will only give rough temp of of the surface of the cpu socket/heatsink (depending where you point/touch it) though so aren't that useful.
As for the plastic film on the bottom of the heatsink, this pic shows what I mean:
Four-heat-pipe-CPU-Cooler-Heatsink-for-Intel-LGA1150-LGA1151-LAG1155-LAG775-LAG1156-AMD-FM2-FM1.jpg_960x960.jpg.4ab19a9a8f8e585ae35e04aa3b65c50a.jpg
https://linustechtips.com/topic/1279141-pc-temperature-average/#findComment-14291506
