Help wanted; RAM Speed vs capacity
Solved by Inhaps,
1 hour ago, We Didnt_t start_the_fire said:basically 24g 2666 cas 20
or
16g 3200 cas 19
wonder is that 1 cas make a difference? or the frequency is too big but then I do hav ean extra 8 g of ram.
Put simply, divide CAS latency with frequency and pick the one with a smaller result. Your 16Gb will generally be better, not even taking into account performance problems with mixing differently sized sticks. Only reason to get the 24Gb is if you could run out of memory with 16Gb.
