I'm building my first PC need help
Solved by Gazereths,
OK remove all front panel connecttions and short the power switch connections with a screwdriver or simnilar (touch the power switch pins on the motherboard at the same time with a metal obeject) see if the PC turns on.
Featured Topics
UGAATL ·
Posted in LTTStore.com Merch1 -
1
7
Mark Kaine ·
Posted in Displays4 -
3
3
tippytipper ·
Posted in Storage Devices2 -
2
AlyShazli ·
Posted in New Builds and Planning24
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
