I took an old payphone and turned it into a case for a PC
deadn0tsleeping
Hello good people. Just wanted to show you my mancave machine. Build description is on the imgur album.
Payphone to PC
The specs are very modest but RDR2 medium quality getting 60fps isn't bad. But seriously made me consider a dedicated GPU. There isn't one that would fit organically, but with a riser I might be able to achieve it.
Any thoughts or ideas? Thanks.
Last mile to go! But I gotta say, this gave me Matrix vibes--not sure why.
Main Rig: Illya V2, the Tiny Titan: ||i7 8700k 5GHz @ 1.385v (delidded)|| ||NVIDIA RTX 3090 FE|| ||KrakenZ63|| ||ASRock Z390-Phantom-ITX/ac|| ||Corsair SF750||
2nd Rig: Illya V1, the Air Cooled Prodigy: ||i7 4790k 4.4GHz @ 1.3v|| |NVIDIA RTX 2080 FE|| ||Be Quiet! Dark Rock 2|| ||ASRock Z87-E|| ||SeaSonic G-Series 550w (Carbon Fiber Mod)||
Captain isHypnophobic of the LTT Conglomerate.
