Question about Push-Pull fan configuration
Solved by For Science!,
21 minutes ago, zeroskie said:Just reading online and looking through my MOBO user guide, I don't think the X570 Tomahawk has a 2-pin temp sensor. Maybe I'll need to get a controller of some sort, but I don't really want to deal with a software solution. I was hoping to just set the fan curve in the BIOS.
Yes, as a linux user, I totally understand that you want a self-contained system. If your board doesn't have a sensor header, it may be difficult to achieve cleanly. Something like the Aquaero would be ideal, although it is not trivial to setup.
