Advice for cooling Ryzen 5800X
ALB112
Hello I already purchased the Ryzen 5800X and currently have the Noctua NH-U12S and was wondering if I should get a different cooler for this CPU.
My case is the Fractal Design Meshify C and I have 2 Noctua NF-A14 in the front for intake and 1 for exhaust at way back and then another fan up above the CPU cooler. For those other fans I am using stock fans from the case.
any suggestions for improving? I realize using an AIO, but I don’t prefer bc of its caveats. Unless y’all think so?
If it works and the temps are fine, then stick with what you have.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Would you recommend an AIO though to cool the 5800X?
Well what are your temperatures like with the Noctua NH-U12S??
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Right now I’m getting 30 idle and when I game but it depends on the title like 50-60ish
Those are really good temperatures. I wouldn't bother getting an AIO as those temps are perfect.
  • 1 month later...
Im reading lot of people wondering why someones 5800x hotter than others, guess someone uses slilent mode and others dont. That changes core boost speed
Im getting a u14s, my amd wraith prism cooler goes in worst case to 91 in games
got now the u14s
idle 40-35, max temp 89, gaming was 79-82
that was with default setting in bios on msi tomahawk wifi
55 minutes ago, Ramza said:
got now the u14s
You should be generally okay with those temps, I'd see if you're really getting enough air in the case at this point to make sure that the cooler is getting enough cool air through it. I'd probably say you're borderline at that point and would recommend an NH-D15 instead of the U14S but that's up to you
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
